Topic: 2007 190 MONTAUK Mold Forming on Silicon Sealant
Whalerdog |
posted 07-29-2008 07:53 PM ET (US)
I have 2007 Boston Whaler 190 Montauk. The white silicone in the rear where the water lays has turned black. Looks like a magic marker in few spots. I tried most everything to remove it. I was going to go over it of cut the small area out and reseal it. What is the best kind [of sealant and best] brand [of sealant] to use? I saw 3M and the had regular and extra strength. Thanks!
Chuck Tribolet
posted 07-29-2008 08:59 PM ET (US)
I'd leave it alone. Chuck
dauntless14
posted 07-29-2008 09:08 PM ET (US)
[I] have the same problem. [I w]ent ahead and cleaned [the portions of the sealant which were covered with black mold] with acetone then applied a thin layer of 3M5200 over the existing caulk. |
Bella con23
posted 07-29-2008 10:20 PM ET (US)
I had the same [problem] and found that a terry cloth rag and some boat soap worked into the caulk joint cleaned it up nicely. I don't think that the mold had a chance to penetrate the caulk, however it was black when I started. Joe |
Whalerdog
posted 07-30-2008 05:20 PM ET (US)
Guess I'll rub some more with soft scrub. I did put some on overnight like a poultice. Damn spot looks just like a super marker dot. You would think they could put some kind of fungicide in the silicone to last for a few years. I wash it every five days and rinse it even more frequent. Rinse it every time out which is at least every other day weather permitting. Thanks for the help. |
posted 07-31-2008 09:17 AM ET (US)
Prevention being useful, a cover to keep water out and a sponge to remove all traces after cleaning or use could be a problem solver.Butch |
Whalerdog
posted 07-31-2008 05:43 PM ET (US)
Butch good info thanks I try my best to do that. Sometimes with work I can't look out the window I am so tired. Wish they made it drain better there. Hardly anything stays there and the boat in in the water so it does rock and remove all but a half cup or less on each side. If I had the dough I would enclose the floating dock with a fabric like car tents they sell. The dock does rattle and roll slightly so it is probably not feasible. Thanks! |
chopbuster
posted 08-05-2008 07:28 PM ET (US)
I watched an old-timer use an artist's small brush to paint the black mildew stain with diluted bleach and rinse with water; the stain disappeared. |
Whalerdog
posted 08-05-2008 08:29 PM ET (US)
Tried to scrub it again and did try commercial bleach left on over night to no avail. Got a tad lighter but it still bugs me. |
posted 08-05-2008 09:05 PM ET (US)
[Moved to the POST-CLASSIC discussion.] |
Sal A
posted 08-06-2008 05:16 AM ET (US)
Try using Amazing Roll - off. Let it sit for ten minutes. Then work it. It will work. |
poker13
posted 08-08-2008 03:02 PM ET (US)
If bleach didn't kill it, it can't be algae, mold or mildew. Household bleach, like Clorox, will make that stuff disappear in minutes. I wonder what it might be. |
Whalerdog
posted 08-08-2008 06:54 PM ET (US)
it is some type of mold that penetrated they silicone |
swist
posted 08-09-2008 12:53 PM ET (US)
I've seen this on boat caulk, mainly silicone, the mold/mildew is actually forming inside the cured sealant. So putting bleach (or any other cleaner) on it doesn't do a thing.When this happened to me on my pre-Whaler boat, it was mainly at the joints of all the pieces that made up the cockpit on a cuddy-cabin ProLine. I had to scrape out the old stuff and recaulk it. I suppose you could also caulk over the old stuff, but that wouldn't be as neat as the beads would be too big. |
Whalerdog
posted 08-11-2008 03:34 PM ET (US)
I caulked over it today. It is recessed quite far and it still looks neat. See if it comes back. I may spray it every day with 3M mold remover. 3M also make a mold preventive spray. |
