ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Post-Classic Whalers 170 MONTAUK: Corrosion on Steering Wheel; Auxiliary Motor Bracket
Author | Topic: 170 MONTAUK: Corrosion on Steering Wheel; Auxiliary Motor Bracket |
missmia |
posted 02-22-2009 06:04 PM ET (US)
I have a 2008 Montauk 170. I noticed small amounts of rust forming at the weld [between] the spokes and center drum of the stainless steering wheel. Have others had this problem? What is the recommended brand of auxiliary motor mount for the 170 MONTAUK? I saw the REFERENCE article for mounting directly on the transom, but I probably just prefer four bolt fasteners of a motor mount over cutting into the aft deck for direct transom mount. I plan on just a 4-HP |
SC Joe |
posted 02-22-2009 06:52 PM ET (US)
I have not had any rust on my 2008 170's steering wheel. However, this boat is stored in a garage, under a cover. I did find this "Made in China" sticker when replacing my Montauk's wheel, which may explain your [corrosion]. |
fisherman |
posted 02-22-2009 07:24 PM ET (US)
I thing if you do a search on this site you will find several bolt on brackets. Both Manually operated and electric. |
fishinchips |
posted 02-23-2009 10:03 PM ET (US)
Here is a sample: [url]http://s7.photobucket.com/albums/y264/kjang/kicker%206hp%20Merc/kicker%20mount/[url/] |
missmia |
posted 02-23-2009 11:39 PM ET (US)
thanks all...fishnchips: looks like a pretty sturdy bracket...I like the piece of HDPE spacer btwn the bracket and transom. |
Kencvit |
posted 02-24-2009 07:17 PM ET (US)
http://s7.photobucket.com/albums/y264/kjang/kicker%206hp%20Merc/ kicker%20mount/ |
