Topic: 190 MONTAUK: Hydrofoil Fins
John6789 |
posted 04-19-2009 10:11 AM ET (US)
[Seeks] experience and suggestions for hydrofoil fins for a [Boston Whaler 190 MONTAUK] with a Mercury 115-HP FOURSTROKE. Which model fins? Does the no-drill mounting system work well and stay on? I [want the boat] to get onto plane sooner and reduce bow rise.
jg125
posted 04-19-2009 12:19 PM ET (US)
I have a 2008 170 Montauk with the 90 FourStroke. I put the bolt-less StingRay fin on it and like it very much. I also had it on my 2006 150 Sport with the 60 FourStroke. It is easy to take on and off, has held on fine for me so far (two full seasons). I will always use it.JWG |
highanddry
posted 04-19-2009 12:54 PM ET (US)
Just put on tabs, I did on my 190 Outrage or Nantucket, huge difference all around. |
posted 04-19-2009 02:45 PM ET (US)
Check with Mercury to see what they say about drilling through the anti-ventilation plate of a motor that is under warranty. |
SC Joe
posted 04-19-2009 04:04 PM ET (US)
I just don't see the need for these devices. These boats plane very quickly. |
posted 04-20-2009 12:23 PM ET (US)
Joe - It is not about time-to-plane, some owners want to attain and/or maintain a plane at a lower speed. |
jg125
posted 04-20-2009 01:10 PM ET (US)
The one I have does not require any drilling. I have a Sting Ray XRIII fin. It slides on the cavitation plate and is held in place by the anode /bolt. I got mine after a freind bought his new 150 Sport several years ago from a local BW dealer with it dealer installed. He loved it, so I bought one for the 150 Sport I had at the time. It was inexpensive, real easy to install/ remove, makes no marks on the cavitation plate (I remove it for winter storage) and I am very happy using it. I now have it on my 08 170 Montauk. I believe that the boat gets on plane quicker and stays on plane at lower speeds. I think that it has helped fuel economy too. I have read that top end speed may be negatively affected, but that does not bother me. I have been happy with mine. |
sapple
posted 04-20-2009 04:26 PM ET (US)
According to previous threads on this subject Mercury does not recommend use of these devices. |
John6789
posted 04-20-2009 08:42 PM ET (US)
Thanks for all your thoughts. Phil T is correct, it is about achieving and maintaining plane at lower speeds. I don't know how to evaluate which fin would be best but I will buy and try one of them (probably the stingray) and write back. I am a bit hesitant toward trim tabs due to complexity and cost. |
Sal A
posted 04-20-2009 09:00 PM ET (US)
On a 19 foot boat, I'd get tabs (I had the 190 Nantucket with tabs once upon a time).And Phil T is right. Some bodies of water have a very short chop. Too choppy to go too fast, yet sitting in the hole below planing speed is a drag (no pun intended). Planing at lower speed is the goal. |
fishinchips
posted 04-20-2009 11:04 PM ET (US)
For a long time I was opposed to fins. Then I put one on and loved it ever since. The reason why I like it is because I can acheive a lower planning speed. It helps alot when the seas are a bit nasty. I just can't stand falling off of plane. Then speeding back up to get on plane then you pound yourself to death. Now, the fin does not correct listing. So if you have a listing problem, then get the trim tabs. Ken |
Feejer
posted 04-21-2009 07:23 AM ET (US)
I wonder how it would work on a Verado 150 and Dauntless 180. I might try the no drill Stingray, I don't want to drill cav plate. The largest tabs I can install are 9 x 9. |
gwcpa
posted 04-27-2009 10:04 AM ET (US)
Sal,If you have any pics of the tabs installed, I'd appreciate it if you could direct me to them or shoot them to me in an e-mail. My 190 has a Stingray "hydrofoil fin" on it now which helps quite a bit in lowing the planing speed and getting the boat on plane with a large load. I may try a permatrim as well, but I'm trying to picture how the tabs fit with the swim platform installed, which I assume you had. I know you had a lot of pics on the web at one time, but this may have been with the old AOL site that is now defunct? |
Feejer
posted 04-27-2009 10:55 AM ET (US)
I'll be trying a Mercury Vensura SS 4 blade Propeller 14-1/2" x 17" on my Verado 150 late next week. I'll let you know what if anything it does for me.I've been told by Prop Gods this should lower my planing speed a few mph while adding some stern lift. I'd rather change the prop than put on trim tabs for what I need |
20dauntless
posted 04-27-2009 07:23 PM ET (US)
I have the SST hydrofoil on my C-Dory 22 with Honda BF90D. I had it installed at my Honda dealer, and since the one I bought was Honda branded and installed by an authorized Honda dealer my warranty is apparently not void. I also have Bennett tabs installed, and I find I use tabs for lateral trim and the motor for fore and aft trim. This seems to give me the best fuel economy and performance. When it's really nasty, I can have the engine fully tilted down and the tabs fully deployed and plane down to 8-9 mph.The general consensus over on the C-Brats website, where many of us have either the SST or the Permatrim, is that these hydrofoils cost you a little bit in top speed, perhaps a little in fuel economy, but the difference in planing speed and comfort is definitely worth it. I've toyed with getting one for the Whaler but hesitated because of the forces involved. Whereas the C-Dory tops out at 30 mph, the Whaler does almost twice that. I just am not convinced that it would be good for the engine to have that kind of force on it... |
gwcpa
posted 04-27-2009 09:18 PM ET (US)
Mine tops out at about 30. ;)Going to maximize my slow speed use. |
