posted 03-27-2011 05:49 PM ET (US)
I bought a 1997 OUTRAGE 20 about five months ago, when I moved to the Bahamas. It has a Mercury 200-HP Offshore motor with carburetors. The motor was in outstanding condition but recently ceased functioning. It has a nick on the top of the #4 cylinder and a matching nick on the head. It appears the motor swallowed something and #4 chewed it up. The cylinder walls are scored and the compression is now 70-PSI, down from about 120-PSIKeep in mind NADA value for this motor is a little over $,2000 and it is a gas and oil guzzler. My choices are to:
--re-build the engine myself with unknown outcome--haha;
--buy a remanufactured powerhead for $2,700 with a one-year warranty;
--send entire motor out for rebuild [over] $3,000, plus shipping;or,
--re-power for somewhere between $12,000 and $18,000.
The specification for the hull are length 19' 8", beam 8' 4", draft 15", dry weight 2,350[-lbs], swamp aapacity 4,800[-lbs], persons capacity 9, fuel capacity 87[-gallons], maximum HP 225, minimum HP 130, engine shaft 25".
Whaler tells me maximum recommended motor weight is 540-lbs. This means any four-cycle engine over 150-HP is out except for the Suzuki 175. The original 200-HP Mercury weighs 398-lbs for reference
To my best knowledge my only options are:
--175 Suzuki 485-lbs, with largest output for displacement;
--200 E-TEC 433-lbs, with largest output for displacement;
--225 E-TEC 524-lbs;
--200 or 225 Optimax 505-lbs
--200 HPDI Yamaha 475-lbs.
I have heard great things about the Suzuki and E-TEC, bad things about the HPDI, and not so great about Optimax.
I am looking for reliability, low maintenence, and low operating costs. My usual load is half a tank, four people, light fishing gear, freedive and spearfishng gear. My guestimated operating weight is around 4,200-lbs with the above items. The boat also has 12x12 trim tabs.
Is a 175-HP four-cycle engine going to be enough? Similarly weighted boat tested: (low load test weight is similar to my full load and boat size)
3.72MPG 22-nautical miles per hour at 4,000-RPM and WOT 20 nautical miles per hour at 6,200-RPM. Source is http://www.suzukimarine.com/uploads/09_Dusky203Open_SZ175.pdf
Or, do I need more power? Right now loaded up I cruise at 23 nautical miles per hour at 4,000-RPM and WOT 38 nautical miles per hour at 5,800-RPM. I do not need to go this fast. My [most distant] fishing location is 12 miles away. Speed is nice, but efficiency will encourage me to go out more. Also, this boat will be used at least once a week for as long as I live in the Bahamas. I also will not be able to go to a dealer for installation and service.
Please let me know what your opinions are in my situation. What would you do?
