sheikofthesea |
posted 06-22-2012 02:36 PM ET (US)
[Started a new thread instead of following up to the existing discussion. Please do not start a new thread to post follow-up information to an existing discussion, especially when the discussion is a recent discussion only a few days old. Information is of much more value when it is collected and organized. If you feel you must start a new discussion, if you make reference to a prior discussion you should give the uniform resource link or URL to the prior discussion so that readers will be able to locate that discussion. This is particularly necessary if you are going to make reference to the prior discussion as if all readers of your new discussion were aware of the prior discussion. I have moved you new discussion to your prior discussion. It saves me a lot of time and work if you would just append your follow-up to the original discussion. Thank you--jimh]
