  BlueSea Electrical system schematic w/out Main Feed Fuse
Author Topic:   BlueSea Electrical system schematic w/out Main Feed Fuse
hullinthewater posted 04-03-2014 04:58 PM ET (US)   Profile for hullinthewater   Send Email to hullinthewater
I'm in the process of installing an entire new 12V system into my Super-Tauk.
I'm using this BlueSea general schematic as a guide, except I wont use the ACR or the dimmer.
http://www.bluesea.com/systems/42/2_Battery_Bank_1_Engine_Electical_System
If memory serves correctly, a past thread describes using a 30 AMP fuse between the Batt switch and the (+) distribution buss.
Could it be the generalized nature of the BlueSea schematic that it's omitted?
My system will have a 8" x 16" panel with:
1. a Batt 1-2-Both switch,
2. 10 circuit (+)Buss, 10 circuit (-)Buss
3. a 6 circuit ATC Fuse panel for Switched loads
4. a 6 circuit ATC Fuse/Switch WeatherDeck panel for Un-switched loads [surface mounted exterior access].
Except for the Engine Start/Tilt control, the 'House circuits to the stern are [+/- 12']:
(2) Bilge Pumps
(2) Lights [Stern Nav LED, Stern/Deck illumination LED]
All other circuits start and terminate in the console will be no more than 20amp ea, or less.
[GPS, VHF, Fishfinder, Stereo, Nav LED, Foredeck LED, Console Interior LED, 12V Charge port]
The Batt Selector is mounted within 12" of Batt's on one end of 8"x16" panel, then 'Switched' loads FuseBox, then the 2 Buss' distribution bars will be at the aft end of panel.
The panel itself is accessible from the front seat lid opening of the console, immediately next to the two batteries.
In my design, is a 30 amp fuse necessary/recommended between the Batt Switch and the (+)distribution buss?
Thanks for reading and input.
Joe
hullinthewater posted 04-03-2014 05:02 PM ET (US)     Profile for hullinthewater  Send Email to hullinthewater
EDIT:
Except for the Engine Start/Tilt control, the 'House circuits' to the stern are relatively low amperage and +/- 12':...
