This is not true. There was no basis for you statement that you were unable to attach a larger image than a 320 x 240 pixel image of 25-kBytes that was imposed by the forum.MJH wrote:I wasn't able to attach a larger picture due to a size limit.
But first, please note that generally problems with using the forum are not discussed in the boating forums. You should post your problem with the forum software in the forum that is intended for those sorts of discussions. In the future, please use the forum INTRODUCTION TO THE FORUM SOFTWARE when you want to discuss problems with using the forum. You can find that forum listed in the index, or you can jump to it with this link:
https://continuouswave.com/forum/viewforum.php?f=1
If you looked into the forum INTRODUCTION TO THE FORUM SOFTWARE you would discover that the limit on hosting images files that are to be included in the forum discussion is much larger than the image you posted.
The image you posted has a pixel size of only 320 x 240 pixels. The limit on image size is 900 x 900 pixels. This means your image was very significantly smaller than the limit.
The image you posted has a file size of only 25-kbytes. The limit on image file size is 250 kbytes. This means that your file was very significantly smaller than the limit.
Also, when trying to use images for illustration, there is no need to include extraneous elements that might appear in the image that are not particularly relevant to the goal of the image as an illustration of some implementation or concept.
Here is the image you provided after being cropped to eliminate unnecessary elements and then expanded to a larger size:
Unfortunately, because your original file was so limited in resolution, the image remains very rough and difficult to read.
Also, if you post an image that includes CALLOUTS to various components using numbers, please include a LEGEND that explains the meaning of each numbered item. Without that information the CALLOUTS are useless and just clutter the illustration.
