Cable with ref 000-0120-62
raulsueca
Postby raulsueca » Mon Mar 27, 2023 1:49 pm
Q1: What is the pin out of cable with ref 000-0120-62 at the Evinrude end?
Fig. 1. An Evinrude cable with unknown signal and pin assignments.
Re: Cable with ref 000-0120-62
Postby jimh » Mon Mar 27, 2023 5:08 pm
The cable shown in Figure 1 is a NMEA-2000 drop cable for connecting the NMEA-2000 port on the legacy E-TEC engines to a NMEA-2000 network wired with the DeviceNet Micro connectors.
You can deduce the pin assignment at the E-TEC end from the wire colors in the mating connector. The wire insulation color code follows the standard NMEA-2000 color code.
For information on DeviceNet connectors see
https://continuouswave.com/forum/viewto ... =714#p4771
