I-Command Gauges and Literature
Posted: Wed Jun 17, 2020 7:23 pm
Evinrude has used the branding of I-Command with two distinctly different types of NMEA-2000 gauges.
An early and lesser-known variation of I-Command gauges were sold in c.2005 and were dial pointer gauges with an LCD display and three input buttons for user control. These were later called I-Command Classic gauges.
Fig. 1. The Evinrude I-Command Classic RPM gauge.
The best known I-Command gauges are adapted Lowrance LMF-400 and LMF-200 gauges with LCD displays with 1-bit or black-white graphics, and these were sometimes referred to as the "I-Command Digital" gauges to distinguish them from the earlier I-Command Classic gauges.
Fig. 2. The Evinrude I-Command Digital gauge.
Both I-Command Digital and I-Command Classic series are now obsolete.
I have archived literature about these older gauges.
A 2005 rigging guide showing I-Command Classic gauges is a four-page document. See http://continuouswave.com/whaler/reference/NMEA2000/I-Command.pdf
A 2005 installation and rigging guide showing I-Command Classic gauges is a 50-page document. See
http://continuouswave.com/whaler/reference/NMEA2000/I-CommandInstallation.pdf
The newer and more common I-Command Digital gauges that are essentially identical to Lowrance LMF-400 and LMF-200 gauges differ only in having special firmware loaded on them that can provide special functions useful with E-TEC engines. I also have archived literature about these I-Command gauges.
A 2008 Supplement is a 16-page document that shows many products and block diagrams of rigging.
http://continuouswave.com/whaler/reference/BRP/I-CommandSupplementRev.pdf
A 2008 I-Command Installation guide is a 50-page document that shows both older and newer style I-Command gauges.
A 2008 I-Command Three-in-one User's Guide is a 112-page comprehensive document with installation guide, basic operating guide, and extensive tutorials on creating custom display pages and other modifications to the default display configuration for the I-Command Digital gauges.
http://continuouswave.com/whaler/reference/BRP/ICommand3inUsersGuide.pdf
And a 2010 I-Command Digital Network Guide is a 40-page document that shows only the Lowrance LMF style I-Command Digital gauges and only the modern NMEA-2000 DeviceNET Micro connector rigging.
http://continuouswave.com/whaler/reference/BRP/ICommandInstallation2010.pdf
Links to these documents have been posted in the REFERENCE section index page for many years, but I am adding this article to this forum to inform readers here of these resources.
