ICON Touch 4.3 and NAUTILUS 3.5 Gauges: No Engine Data
Posted: Thu Mar 09, 2023 2:26 pm
by Sigfritaly
Good evening everyone. I introduce myself, I am Siegfried and I am writing to you from Marsala, Sicily (Italy).
I have an Evinrude E-TEC G2 300-HP engine with two instruments: a NAUTILUS 3.5 inch display, and an ICON Touch 4.3-inch display. Both instruments often do not give any engine data readings. Nor do they report any error alerts.
Please give me an idea on what to check.
Re: ICON Touch 4.3 and NAUTILUS 3.5 Gauges: No Engine Data
Posted: Fri Mar 10, 2023 7:44 am
by Sigfritaly
The cause of the problem has been found: a faulty connector [in the NMEA-2000 network wiring that looks like a terminator].
- Fig. 1. A component of a NMEA-2000 network that appears to be a terminator.
- NMEA-2000terminator.jpg (11.1 KiB) Viewed 14396 times
Posted: Fri Mar 10, 2023 10:19 am
Thanks for the follow-up on the solution to your problem of loss of all data on the two engine displays. Typically if multiple display devices cannot display data that should be available on the NMEA-2000 network, the problem is either due to the device that is sending that data (in this case a modern engine with NMEA-2000 capability), or with the network wiring itself.
The component seen above (in Figure 1) looks like it is a terminator for the network. Without proper network termination the electrical signals on the network may not be properly transmitted or received.
