I-Command Engine Warnings Option
Posted: Tue Oct 17, 2023 1:04 pm
by FredBoykin
While operating my Evinrude I-Command gauge, in the SYSTEM SET UP menu there is a submenu for ENGINE WARNINGS. There I got the screen display shown below:
Fig. 1. I-COMMAND screen.
Q1: what does the notation "v1.111B Wrngs" refer to? I assume it is a version number.
The only warnings I had previously seen were LOW OIL and ENGINE OVERHEAT.
Q2: should this option be enabled?
The I-Command gauge user's guide doesn't go into much detail.
--Fred
Re: I-Command Engine Warnings Options
Posted: Wed Oct 18, 2023 9:18 am
Return to that option in the menu and press the ENTER button. Describe what occurs next.
FredBoykin wrote:Q1: what does the notation "v1.111B Wrngs" refer to?
The notation "v1.111B Wrngs" sounds like a firmware revision number.
Posted: Wed Oct 18, 2023 6:35 pm
by FredBoykin
The option at the ENGINE WARNING menu is to either TURN ON or TURN OFF the function.
Fig. 2. Menu option
Fig. 3. Menu choice confirmation screen.
I assume safest choice is to select TURN ON.
Q3: why would I choose to TURN OFF the warnings?
Perhaps choosing TURN OFF warnings would allow the aural warning horn to be silenced until the problem can be remedied.
Posted: Thu Oct 19, 2023 10:13 am
FredBoykin wrote:I assume safest choice is to select TURN ON.
I don't know how safety will be affected, but I cannot see any harm in enabling the engine warnings.
FredBoykin wrote:Q3: why would I choose to TURN OFF the warnings?
I cannot foresee a reason to disable the warnings. Again, I cannot see any harm in enabling the I-Command gauge to display ENGINE WARNING data.
ASIDE: to reduce glare and reduce reflections in the display surface, drape a black cloth over the display and over yourself when photographing the display.
Posted: Thu Oct 19, 2023 10:40 am
by FredBoykin
Thanks for your comments. Appreciate the advice.
Posted: Thu Oct 19, 2023 11:02 pm
I have a question for you: what is the I-Command gauge firmware version?
