I see in the literature and owner's manual I received with the [Boston Whaler 190 MONTAUK] boat the part numbers [for replacement fenders for the Karavan trailer] are
310-02070 RH
310-020-69 LH
The trailer is not near me. Are the tires 14-inch or 15-inch?
A drawing showing the trailer just says fender and rim [without] sizes.
I called dealer for Karavan and they seem lost with [those] part numbers.
I see some from Great Lakes Skipper which seem similar. They offer no part number just that they are from a Bayliner trailer and 37-inch-long.
Googled name and part numbers with no success.
Any help us appreciated.
Can't tell length of my fender as some of it is gone. Width is about 9.5-inches. Height is 11-feet [inches], and length may be 37-inches, but some is missing.
Replacement Karavan Trailer Fenders 190 Montauk
Re: Replacement Karavan Trailer Fenders 190 Montauk
Have you tried Karavan direct 920-928-6200 Option 3
Re: Karavan trailer fenders 19 Montauk replacement?
Fifteen inch on the Karavan that came under our 190 Montauk.
Karavan has been most helpful. You may need your vin which is on your registration papers.
Re: Ordering From Karavan
Ordering from Karavan. Each fender$24. [KARAVAN] changed the way [the fender] mounts. No screws from bottom. Now carriage bolts 3.xx.
[KARAVAN] said fenders are 40-inch long. When I get to boat I'll measure the fender that is intact.
Also check if I need a [lamp] or grommets.
Part number I gave was whole assembly.
Thanks all.
Thanks all.
Swapped them out. Mounting tabs on trailer were rusted. Wire wheeled 99-percent of the rust off the brackets. Use rust converter, spray galvanized, and then Por15 undercoating. Two new lights and it's done.
Thanks for the update.
I cracked one of mine (I'm to heavy for that plastic) and must replace it. good to know Karavan is helpful.
No clue what you weigh but I think fenders only crack after aging from UV damage. I would bet 300 lb. would be safe. They bolt on in existing holes now. New LED light and rubber gasket was cheap too just under 4 bucks.
