1989 Mercury 90 Only Reaches 4,000-RPM
Posted: Sun Oct 08, 2017 7:42 pm
by enggass
Today I had a chance to get out my 1989 Mercury 90-HP. The maximum RPM was 4,000 and boat speed was 25-MPH. It was windy and choppy.
[Later more information is provided. The recommended wide-open-throttle engine speed for this 1989 Mercury 90-HP is said to be 5000 to 5500-RPM, the boat is a Montauk and assumed to be a 17-foot model, and the anticipated boat speed is thought to be 42-MPH--jimh]
[What are your] thoughts?
A 17-pitch propeller.
Thanks.
Re: Engine concern - what to look for?
Posted: Sun Oct 08, 2017 8:51 pm
by Don SSDD
Check plugs, see if you are firing on all cylinders.
Re: 1989 Mercury 90 Maximum RPM
Posted: Mon Oct 09, 2017 7:10 am
Need more data:
--what is the manufacturer's recommended speed range for this engine at full throttle?
--what is the gear ratio?
--is this limited data you report supposed to be something abnormal?
--what boat is this data about?
Posted: Mon Oct 09, 2017 7:32 am
by enggass
Montauk 17
Should be [5000 to] 5500-RPM
42 MPH top speed
Posted: Mon Oct 09, 2017 7:39 pm
Use an inline spark check tool to verify you have spark on all cylinders.
How many cylinders does this engine have?
Is the engine a two-stroke-power-cycle engine?
Does this engine use carburetors?
Has the boat speed previously been 42-MPH at WOT?
What is the gear ratio?
