1996 Outrage 17 Swim Ladder
Posted: Sat Jul 28, 2018 6:45 pm
by Matt164
I finally got a Boston Whaler boat[—a 1996 OUTRAGE 17]. [At some time] before this boat had a ladder off the [transom]. I'd like [to buy] one. Where should I look [to find a swim ladder for a 1996 OUTRAGE 17 for mounting off the transom]?
Re: 1996 Outrage 17 Swim Ladder
Posted: Sun Jul 29, 2018 6:25 am
Swim ladders are available from many vendors and in many styles. My expectation is any swim ladder or boarding ladder previously installed was an off-the-shelf commercial ladder, and not something fabricated by Boston Whaler specifically for that year and model boat.
On many Boston Whaler boats the boarding ladder is mounted to a small platform installed on the transom and supported with a custom-bent stainless steel tube which also functions as a hand railing and aids the swimmer in climbing aboard. If that platform is not on the boat, then you will have to create something similar for mounting a stock swim ladder.
This newer Outrage has a boarding ladder mounted to a small platform on the port side of the transom.
Posted: Thu Aug 02, 2018 7:36 pm
For OEM, contact your local Boston Whaler dealer to see if the current swim platform is available.
This is from the Resources section of Whaler.com showing the diagrams for a 1999 Outrage 17 II
Here is the diagram showing the details:
http://bostonwhaler.com.s3.amazonaws.com/resources/170-Outrage-Hull-Assembly-Sheet-1-of-2-1999.pdf
The platform is item #47. The ladder is #48 on this parts list:
http://bostonwhaler.com.s3.amazonaws.com/resources/170-Outrage-Hull-Assembly-Parts-List-1999.pdf
If not available or realistically priced, contact Ray Martin @ Martin Marine Design. He makes swim platforms made for Whaler transoms.
http://www.martinmarinedesign.com
Aside: Jim, Is that Nick, aka Bigshot, from back-in-the-day?
Posted: Sat Sep 12, 2026 5:49 am
by AlastairOR17
[Revived a thread that has been dormant for eight years in order to change topic--please start a new thread.]
