According to one source, the deadweight tonnage (the weight of the ship and its cargo) for the EMMA MAERSK-class container ship in metric-tons (2,200-lbs) is 165,000-metric tons, which is 363,000,000-lbs. Compared to say a Boston Whaler MONTAUK 17 that weighs perhaps 2,500-lbs with an engine, fuel, crew, and gear, that is a weight equivalent to 145,200 Montauk-type boats.
The EMMA MAERSK fuel economy of 28-feet/1-gallon can be compared to the collective fuel economy of 145,200 Montauk-type boats. Let us assume a modern Montauk with a efficient outboard consumes fuel at a rate of 5-miles/1-gallon or 26400-feet/gallon. The net fuel consumption of 145,200 Montauk boats would then be 26400-feet/145,200-gallons = 0.182-feet/gallon. This suggests that in terms of moving the same weight of hull, engine, and cargo, the EMMA MAERSK is more efficient than a fleet of Boston Whaler MONTAUK 17 of the same total weight by a factor of 28/0.182 = 154-times. Or stated slightly differently, a MONTAUK would need to get a fuel economy of 770-MPG in order for the fleet of 145,200 Montauk boats to consume the same amount of fuel as the EMMA MAERSK in terms of their total weight moved a particular distance with a certain volume of fuel.
Also, MAERSK now operates even larger container ships, the EEE class. Although they are not much longer or wider, by careful design their capacity is 16-percent greater. And--this should come as a surprise to many--their
efficient diesel engines are
two-stroke-cycle engines.More on the EEE-class (for Economy of scale, Energy efficient and Environmentally improved) at
https://en.wikipedia.org/wiki/Maersk_Triple_E_class
