Drain Path 26 OUTRAGE
steelogreen
Postby steelogreen » Mon Jun 14, 2021 8:43 pm
[On a c.1999 OUTRAGE 26] from inside the cabin at the head where does the water drain?
I don’t want to pressure wash inside before I figure out where that water ends up. Thanks
Postby Phil T » Mon Jun 14, 2021 9:18 pm
Check the diagrams.
Enter YEAR, Model Family, Model and Diagrams.
Download for future reference.
https://www.bostonwhaler.com/resources-and-maintenance.html
I think the water drains via the thru hull drain that goes down to the keel if the drain plug is removed when on plane. Otherwise, use the bilge pump installed.
Remember, go e.a.s.y with a pressure washer. You don't want to rip off any gelcoat or force water in to the hull by accident.
