[Give me advice on using a] pressure [for] washing [a Boston Whaler boat's] deck and hull.
Q1: [what are the effects of using pressure washer on the ] gel coat and [on any] wax [that was on the gel coat]?
[Give me a recommendation for the pressure washer setting for PSI] pressure and for the nozzle [to use].
Pressure washing
Re: Pressure washing
A pressure washer is something to be very wary of with respect to Boston Whaler boats.
If not used properly a pressure washer can peel off the gel coat.
Consider a general household tip and a low pressure below 1,600-PSI.
Better yet, using a stiff brush and a bit of elbow grease is easier.
Thanks, Phil. I think I’ll continue to use elbow grease rather than risk peeling off gel coat.
Start with Simple Green and a stiff boat brush.
For stubborn stains, StarBrite Deck Cleaner. Follow the directions.
For restoring the shine to gel coat, remove the oxidation with a buffer with a wool bonnet and 3M fiberglass restorer.
I really appreciate the advice given.
ASIDE: my Boston whaler boat looks good when it is clean.
Use of a pressure washer is an excellent way to force water into the gel coat and cause osmotic blistering, a very bad outcome.
There is really no dirt that lays atop the gel coat of a Boston Whaler boat that cannot be removed with a detergent an some mild abrasion with a 3M scrubbing pad. Oxidation can also be easily removed with that method, too.
I have had good results using Spray Nine and a stiff bristle brush.
I have used my pressure washer ( 2600 psi) on the deck, top of the gunwales, hull sides, and the hull bottom prior to winter storage for the last 22 years on my 1996 17 outrage II. I have experienced zero problems with my gel coat. The bottom is barrier coated and painted. All other areas are just waxed.
