2004 16 Dauntless Transom Height
Posted: Wed Aug 24, 2022 2:37 pm
My 2004 DAUNLTESS 16 was pre rigged with a Mercury 90-HP ELPTOSW two-stroke-power cycle engine serial number OT942695.
The gear case has a defect.
I found a replacement gear case.
I have learned that my Mercury 90-HP engine is [actually] a model LL with a 22.5-inch lower unit that was only produced for Boston Whaler and only for a few years. The gear case is part number 1667-9011J15.
The 2004 DAUNTLESS 16 transom from the upper edge to the centerline of the keel measures 22.5-inches.
After searching yards and marinas and a established Boston Whaler dealers, [I deduced] this is an obsolete gear case, no longer available as a unit, but some seals and bearings are still available.
Q1: Can a 2004 DAUNTLESS 16 be re-powered an 25-inch shaft engine?
Q2:Can a 2004 DAUNTLESS 16 be re-powered with a 20-inch shaft engine?
Q3: Will the performance of a 2004 DAUNTLESS 16 be satisfactory with a 25-inch shaft engine?
Q4: Will the performance be satisfactory with a 20-inch shaft engine?
The [2004] Boston Whaler catalog gives transom height as 20-inches.
