170 MONTAUK: How to Store Fly Fishing Rods
Posted: Tue Jul 29, 2025 1:47 pm
by fishingproblems
I am seeking method to add [horizontal storage] for fly rods to the cockpit of a 170 MONTAUK.
I would like the storage to be in the inwale of the cockpit below the gunwale.
I am a fishing guide so I usually have anywhere four to six [fly fishing] rods on the boat.
Give me any idea you might have for how to accomplish this.
ASIDE ON A FRIEND
I friend is planning to make an aluminum aft [raised] casting deck for me, with added storage compartments.
Re: 170 MONTAUK: How to Store Fly Fishing Rods
Posted: Wed Jul 30, 2025 10:45 am
Almost anything mounted below the gunwale will intrude on quick and easy movement fore and aft for yourself and your clients. If the rods will have reels attached they will intrude even more. Perhaps some very simple horizontal rod holders to attached to the Montauk's railings with heavy duty Velcro would solve the storage problem. Velcro should also allow for quick access to the rods.
Alternatively, six stainless steel vertical rod holders arrayed across the transom above the engine would not interfere with people movement. Fly fishing over the transom would not be possible but that is possibly not the best place from which to cast. Fabricating a stainless steel tube and mounting six clamp-on stainless steel rod holders to that should not be prohibitively expensive.
Posted: Thu Jul 31, 2025 10:50 am
by fishingproblems
I am going to try horizontal rod holders from SEASUCKER.
Cf.: https://www.seasucker.com/products/horizontal-rod-holders
Posted: Fri Aug 01, 2025 10:27 am
Those horizontal rod holders from SEASUCKER like a good compromise between space and utility. Our previously owned Dauntless 16 had hinged rod holders in the gunwales for horizontal rod storage. When angling with two persons they were useful, otherwise they hindered fore-and-aft movement.
Posted: Sun Jul 05, 2026 1:16 am
by fishingproblems
UPDATE 13 MONTHS LATER
These rod holders [probably means the SEASUCKER horizontal rod holders that were mention in a previous post and to which a URL was given] are perfect for the ALERT 17. But [flyfishing] rods should be [stored] in half and the SEASUCKER [rod holders] should be moved toward the [stern] of the [ALERT 17]. For one-piece [fishing] rods, it [here "it" probably the ability to more around on an ALERT 17 when using the SEASUCKER rod holders that were mention in a previous post and to which a URL was given] might be crowded when moving from [bow to stern].
Posted: Sun Jul 05, 2026 8:43 am
fishingproblems wrote:...rod holders...are perfect for the ALERT 17.
When did the boat under discussion change to an ALERT 17 from the 170 MONTAUK that was mentioned in your initial post?
