Accessories included:
- OEM remote shift and throttle controls, cables, and linkages;
- OEM engine gauges including speedometer, voltmeter, and engine trim
- printed copy of engine owner's manual;
- two 6-gallon Johnson brand on-deck fuel tanks; and
- a fuel tank pad.
The engine paint condition is nine out of ten. On the cowling there is only a little ageing in a few places; paint on the leading edge of the skeg needs a touch up. The engine runs well. In 2024 the carburetors and floats were cleaned and rebuilt, and small fuel lines and clamps were replaced. A hairline crack in the VRO fuel pump was sealed it with JB WELD fuel-resistant epoxy and has worked well since. The engine was flushed with ethanol-free Aviation gas to stabilize for storage.
All of the above was removed and stored during a re-power in Fall 2024. The engine was running well. The engine and accessories were delivered with the boat in the Summer of 1985. Total usage on the engine is literally, 30 weeks of Michigan fresh water lake use when original owner was on family vacations with storage in his garage 51 of 52 weeks per year, one year use in New Hampshire, and then use of the boat stopped in 2015. ) plus one summer in NH. Estimated total engine hours somewhere around 150 to 200. .
Unfortunately, I forgot to get cylinder peak pressures when we pulled it, though I can get them if this would add significant value
If I should separate the controls and cable (which are for a Boston Whaler 15-footer), please suggest separate prices for each, and maybe a full “take it all” package price, too.
