Short Shaft Johnson 65HP for sale
Yes short shaft 15" 65 hp.
Lightweight 225 pounds (factory spec)
Perfect for older Whalers which are stern-weight sensitive
Johnson Seahorse 65HP
Checked out by mechanic 2016. Excellent compression all cylinders.
Lower end oil changed - no leaks
Conventional mechanical shifter
Starts and runs like a champ:
See the video: https://youtu.be/vW0hU8SqCNI
Fresh water use only since I've had it.
Seafoam every tank
Came with my wooden Lyman runabout (also for sale, contact me) but is too powerful for that light 750# boat.
Can test on-water if desired
50:1 Oil premix, I always use synthetic blend.
Well maintained
1968 model
CDI ignition, tuned last year
Alternator 9 amp, electric start
See it in the Johnson catalog at: https://issuu.com/liquidnirvana/docs/19 ... -outboards
Located New England
$700
Might consider trade for 40-50hp short shaft
