$900. Located in Massachusetts, 02739. Must be picked up, no deliveries.
respond to crazy_otter@hotmail.com
Email for pictures or check Ebay and Craigslist Cape Cod, pictures are on both sites.
Information taken from various websites including continuouswave.com
1969 13' Boston Whaler with Venture Trailer.
The 13-foot hull was the original Boston Whaler boat, the one that started it all.
Check out continuouswave dot com for more info on the amazing 13'
In 1958 Boston Whaler introduced a 13-foot utility boat that would soon become the most succesful recreational boat of all time. It was the Volkswagon Beetle of boating.
Fiberglass boats were just being brought to the recreational market in 1958. Compared to other boats of that time, the Boston Whaler offered exceptional utility. The complex shape of the hull could never have been mass produced in wood or aluminum, but its unique design allowed the ride and stability of a much larger boat. The foam filled construction kept the hull weight low, and at the same time provided unmatched floatation. The boat was truly unsinkable. Low weight made for good performance with small horsepower motors, too. The fiberglass laminate and gelcoat made for simple maintenance, while the varnished mahogany seats and trim lent a yachty look to the otherwise spartan boat. The molded liner provided a broad flat interior simply unheard of in a 13-foot boat, and by placing the deck floor above the waterline, the cockpit was also self-draining.
The design of the 13-foot Whaler was extraordinarily innovative, and its continued production over a 40 year span is testimony to that. It is nearly indestructable--almost every Whaler-13 made is still afloat--yet the market for it seems beyond saturation. Year after year, the 13-foot Whaler is a strong seller.
SERIAL or STENCIL NUMBERS
1958-1961...........100 thru 4499
1961-1963...........4500 thru 8499
1963...........8500 thru 11300
1964...........11301 thru 14700
1965...........14701 thru 17500
1966...........17501 thru 21200
1967...........21201 thru 24600
1968...........24601 thru 28500
1969...........28501 thru 2A2400
1970...........2A2401 thru 2A5600
1971...........2A5601 thru 2A7800
1972...........2A7801 thru 2B000
1973...........2B001 thru 2B2700
We stripped the bottom paint, well really it was all over so not just the bottom. You can see by the pictures how much we had to do.
If you want a cheap little whaler that needs some TLC, you can't beat this one.
1969 13' Pre-Sourpuss w/ Venture Trailer $900
crazyotter
Re: 1969 13' Pre-Sourpuss w/ Venture Trailer $900
C -
It really is not that difficult to type capecod.craigslist.org into your browser, enter Whaler in the search, click on the 4th listing, highlight page address, control c for copy, back to CW window, hit URL button, insert page address, control v and DONE.
https://capecod.craigslist.org/boa/d/mattapoisettboston-whaler-pre-sourpuss/6772471199.html
