Appraisal: 1985 Outrage 18
Posted: Tue Jun 15, 2021 1:08 pm
APPRAISAL for a 1985 [OUTRAGE 18] with a 1998 Johnson 150-HP Ocean Runner, and 2007 Loadmaster Aluminum Trailer. The boat has never been kept in the water and has never bottom painted. The boat has been stored inside by present owner. The boat is located in Connecticut.
The boat is set-up for a single engine.
The hull has never been painted.
The [cockpit] was painted with Awlgrip by previous owner.
The teak has been varnished with Interlux Sikkens.
The electronics include a Garmin 545s, a Standard Horizon VHF [OF UNSPECIFIED MODEL], an external speaker, and an AM/FM broadcast receiver.
The boat has [a classic Reversible Pilot Seat]
The boat has a cooler with seat cushions [located forward of the center] console.
The boat has original [forward] vee cushions.
The boat has a Wm. J. Mills canvas set consisting of a FORWARD SHELTER with boot, a SUN TOP with boot, stainless steel frames, and a full mooring cover; all are in like-new condition.
The boat has SeaStar Hydraulic Steering.
There is a small swim platform with boarding ladder,.
Miscellaneous gear such as life jackets, lines, fenders, fire extinguisher and an electric horn are included.
The boat has navigation lighting.
The fuel tank was replaced by previous owner, and design drawings and photographs of the tank are available.
The 1998 Johnson 150-HP Ocean Runner was purchased new for this boat by the second previous owner ago. The engine was service in May 2021 at Boatworks of South Windsor, Connecticut. The service included replacement of the lower unit seals (preventative), installation of a new water pump kit and new spark plugs/ The gear case lubricant was changed. The engine was checked-up overall, and there were no recommendations for any additional work needed.
The stainless steel propeller was rebuilt about 100-hours of engine run time in the past.
A spare aluminum propeller is included.
The battery was replaced in 2020.
2007 Loadmaster Aluminum Trailer was purchased new for this boat by me. The trailer has ALL OPTIONS: hydraulic disc brakes, LED lighting package, bunks setup for 18-foot , spare tire holder with spare tire and spare hub, radial tires, spare tire cover, side loading assist poles with PVC extensions. The wheel bearings were replaced in May 2021. The trailer one of the best available for Boston Whalers with unique frame design and bunks to protect bottom.
This boat has been well cared for by previous and present owners.
The engine is very strong.
The maximum boat speed with proper trim is almost 40-MPH.
The boat cruises very comfortably at 17 to 20-MPH.
