FS: 1980 Revenge V-22 Sterndrive $19,000 in California
rcapriola
Postby rcapriola » Sun Dec 19, 2021 12:12 pm
For-sale: a 1980 REVENGE V-22 Sterndrive in Chico, California for $19,000. The sterndrive is the original Mercruiser Alpha outdrive with rebuilt long-block V8 that runs but needs work. Also included is a Yamaha F9.9 high thrust auxiliary engine with E-Z Steer linkage to the main engine, and a 2019 Kokopeli 6,800-lbs aluminum trailer with disc brakes and spare tire.
Reason for selling: moving to a bigger model.
CONTACT: SMS message to 916-764-5635 (I won’t answer calls from unknown numbers)
Features:
  • 2020 EZ Anchor Puller with 200’ rode, 10' chain, and plow anchor
  • . Bimini top and full enclosure
  • . Dual closed-cell batteries with automatic charging relay and battery switch
  • Automatic bilge pump, backup bilge pump, and high-water alarm
  • . 15-gallon live bait tank (on swimstep)
  • Sound system
  • . Wired for Cannon electric downriggers
  • . Garmin GPSMap 942
  • plus Lowrance Elite-7
  • depth/chart. West Marine VHF
  • new built-in five-drawer tackle storage
  • all thru-hulls replaced in 2019
  • Epoxy coated aluminum fuel tank with all new hoses in 2019
  • power trim motor rebuilt in 2020 with all new hydraulic hoses
  • auxiliary engine carb rebuild, shift cable replacement and lower unit service
  • outdrive service in 2021-new gimbal bearing, bellows, and impeller
  • new engine shift-throttle cable and carb rebuild in 2021
  • new headliner in cuddy 2021
  • rebuilt reverse lockout in 2021
Temporary link: https://sfbay.craigslist.org/nby/boa/d/ ... 31268.html
