FS: Trolling Motor and accessories, $1,000 in Massachusetts
Posted: Mon Jun 20, 2022 10:02 am
For-sale: MinnKota Riptide ST 80 bow-mount trolling motor, saltwater version, 80-lbs trust, 24-Volt, 54-inch shaft with i-Pilot and GPS, in excellent condition, plus all accessories to mount and use on your boat, For $1,000 in Norwell, Massachusetts.
CONTACT: email to TrollingMotor@attglobal.net
Photographs and more information available to interested buyers.
Included in sale are:
More details on the included accessories:
- mounting bracket
- wireless GPS remote control
- wired foot pedal control
- two AGM West Marine Group 31 batteries testing at 12.5-Volts,
- MinnKota two-bank 30-Ampere battery charger, and circuit breaker
- An i-Pilot and GPS wireless remote control which can record and retrace up to 6 tracks 2-miles long each, has spot-lock which holds the boat within 5’ of an “anchor” spot, plus cruise control and advanced autopilot.
- An RTA-17 Quick Release mounting bracket allows you to install / removal easily, or to lock in place.
- A Riptide ST foot pedal control with 18-foot lead, which has never been used. The motor can be controlled by foot pedal or by the i-Pilot wireless remote unit.
- A MinnKota 60-amp circuit breaker.
- A MinnKota 230PC Precision On-Board Battery Charger which can quickly charge two batteries at the same time at 15-amps each for a total of 30-amps output. This charger allows you to select the battery type and can be mounted on your boat or used off the boat, as I did.
- All original manuals, user guides and accessories.
- Two West Marine Group 31 Deep Cycle Dual Purpose AGM batteries, rated at 105 Ah and 1000 MCA, which have not been charged more than 3 dozen times and have been stored in a heated basement when not in use, plus two battery boxes with straps for these batteries, and two battery trays with footmen.
