FS: 1982 OUTRAGE 20 FOR $16,500 in Virginia
Posted: Mon Mar 04, 2024 10:22 pm
by timmytime
For-sale: a 1982 OUTRAGE 20 with 2004 Mercury 115-HP on Load-Rite trailer for $16,500 in Richmond, Virginia.
CONTACT: Tim@BravoDecember.com
Fig. 1. A modified 1984 OUTRAGE 20.
I have owned this 1982 OUTRAGE 20 for ten years. The boat has been used from ten to 20 times every year. The boat has many modifications. The center console is not original to the boat. The forward dodger is from Wm. J. Mills & Co. The below-deck fuel tank has been replaced with a Moeller non-metal tank. The fuel line has a RACOR filter. The leaning post is a TODD NEPTUNE 2. An IGLOO 120-quart cooler is included. A swim ladder is mounted on the transom. A 5-inch SONAR and a VHF Marine Band radio and antenna are included. The ergonomics of this boat are great.
The 2004 Mercury 115-HP engine has a new flywheel, a new starter motor, and a new trim motor. The peak dry cylinder pressure has been measured. The measured pressure readings were perfect. The automatic oil-mixing system has been removed.
The LOAD-RITE aluminum trailer has stainless steel hardware, the spare tire and trailer tires are new or not more than two-years-old, and the wheel bearings were serviced recently.
A sea trial is available.
