Leaning Post Cushion Parchment Vinyl
- John_Madison CT
Would you guys know who might be able to make the cushion for the Whaler leaning post, but in the classic style parchment vinyl?
Re: Leaning Post Cushion - Parchment Vinyl?
John -
Call Tena at Anderson's and ask. 321-267-7028 They have the OEM patterned material, just like Lois at Hall's did.
Anderson MFG and Upholstery, 2770 US HWY Mims ,Fl 32754
- John_Madison CT
Thank you Phil. I left Tena a voicemail a couple days ago.
- John_Madison CT
Re: Leaning Post Cushion Parchment Vinyl
Never heard back from Tena. Tried calling again and her voice mail is full.
For your fabric try:
Art's Auto & Marine Inc
736 Warren Ave
Brockton, MA 02301
Phone: 508-586-2137
Art's was an OEM when Whalers were manufactured in Rockland, MA
736 Warren Ave
Brockton, MA 02301
Phone: 508-586-2137
- John_Madison CT
I tried calling again and got a hold of Tena at Anderson Mfg. She's a nice lady.
I ordered the leaning post cushion. Not cheap, $321, but its with the proper upholstery and tan parchment. They're expecting late January delivery. So, they're very very busy.
Thanks for the help guys. I'll let you know how it comes out.
- John_Madison CT
I filled all the holes and gouges with filler bondo, sanded everything down, refilled, re-bondo any dips, resand everything.
I used a low cost single part Topside paint by Rustoleum. $14/quart from Home Depot. It worked OK. Did about 4 coats, with sanding in between. It's not gel coat smooth, but looks good from 3' away. I did notice that it's kind of soft, which means it will mark up easily, but to refinish in a couple years is easy.
The leaning post was originally a mess. The previous owner put on a huge single cushion, which looked god aweful. It covered the rod holder area too.
So off it came, and what was underneath was terrible.
- image.jpg (52 KiB) Viewed 8767 times
- John_Madison CT
This is what I found underneath:
- image.jpg (35.44 KiB) Viewed 8767 times
Looks nice!
I think you will find the Rustoleum Topsides will harden a bit more over time...mine did. It took about 30 days or so. I refinished the console on my 17' Montauk and it turned out fine.
John - Well done!
