1987 17 Super Sport Limited refresh
TransFueler
Postby TransFueler » Mon Dec 04, 2017 9:09 pm
While figuring out why my Whaler's motor was quitting, I decided to do just a little bit of redo, touch-up, etc.
Fuel System
Drained a lot of water-laden fuel from engine...
Replaced low pressure & high pressure fuel filters.
Emptied & cleaned fuel tanks (Two 9 gals)
Made up new fuel line: A-15 hose, new fittings & bulb
Added a Water Separator / Filter system, between tanks & engine.
Relocating tanks from stern to under aft bench seat. Moves them forward a foot or so for better weight distribution.
Electrical System
Moved 2 Group 24 batteries from stern to under front left bench seat. This moves 90# forward and left, to counter driver in right seat position.
Replacing all battery cables, ends & boxes.
Rewired bow light wiring under new rub rail.
Rewired bilge pump
Added Lowrance 7" color GPS/Chartplotter/Fish Finder
Adding Bluetooth stereo & marine speakers
Hull
Had fiberglass shop fix a deep gouge on starboard bottom & fill numerous previous screw holes, etc.
Installed new rub-rail. No fun, it better last a long time...
Installed bimini top
Installing four rod holders
Will have upholstery shop redo cushions
Installed new fire extinguisher & handheld horn
New dock lines
New 12# Danforth anchor
Two new handheld VHF radios
Before Photo:
2003 Johnson/Suzuki 90 Four Stroke EFI
ShenandoahIndian
Re: 1987 17 Super Sport Limited refresh
Postby ShenandoahIndian » Tue Dec 05, 2017 2:48 pm
Beautiful boat!
TransFueler
Postby TransFueler » Tue Dec 05, 2017 10:00 pm
Thank you. I prefer this layout over the more common "Montauk" version. I've owned various boats for the past 48 (!) years, getting my Sabot sailboat when I was 11. Always wanted a Whaler, and this is my first one...
JDF3
Postby JDF3 » Mon May 21, 2018 8:31 am
I have this exact year boat and lay out. I love it! I'm thinking of completely redoing it and possibly going with teak or even possibly converting into a center console. What would be my best option to go about selling the existing console. I have every attachment that came on the original 87 super sport limited 17. Thanks.
Beautiful boat by the way.
1987 Super Sport Limited
