[Give me a source for a replacement through-hull drain tube] for a 2004 190 Nantucket.
I believe the other [through-hull drains on the boat were made by] Perko.
I am having no luck [finding a replacement drain tube].
Source for Anchor Locker Drain Replacement
roundle1979
Re: Source for Anchor Locker Drain Replacement
I ordered my 2004 Nantucket 190 through-hull fittings from Nauset Marine:
https://www.nausetmarine.com/
190-Nantucket-Thru-Hulls-Assembly-Parts-List-2004.pdf- (48.66 KiB) Downloaded 395 times
190-Nantucket-Thru-Hulls-Assembly-2004.pdf- (88.85 KiB) Downloaded 403 times
Very helpful information. Thank you.
Called Nauset Marine and they were admirable. Got what I needed and some other parts and they are being shipped today. Thanks for the recommendation.
I ordered mine through Sue Lodel but it is not yet installed.
If any of you would share your installation experiences; I would be most grateful.
Mas -
My personal preference is to coat the entire tunnel in sealant or epoxy. Using a long art brush and a narrowed paint stir stick has worked for me. Once cured, dry fit tube. Apply painters tape around both flanges . Apply Boat Life on inside of flange and on the hull. Use a threaded rod with wide washers and nuts to ensure a good (tight but not too tight) fit. Remove rod and tape.
Thanks Phil!
