I am overhauling a derelict 1979 MONTAUK 17. I have found the hull scarred but not waterlogged. Whereas I am able to repair the surfaces and drain-tube holes to prevent future water-incursion, I am struggling for solutions on how to seal and renew the rigging tunnel that runs under the deck from the console to the stern,
The rigging tunnel appears to have once had an aluminum tube inserted, which has now deteriorated and exposes the fiberglass glass to possible water.
I was thinking to try to insert a PVC pipe and seal the ends.
Please suggest a better solution.
1979 MONTAUK 17 Rigging Tunnel Repair
Re: 1979 MONTAUK 17 Rigging Tunnel Repair
Perhaps a new tunnel could be used by installing a new piece of PEXpiping pushed through to the console.
Installing a smaller diameter pipe and sealing the ends is a good approach.
