210 Outrage Leaning Post Livewell Modification
alvarz
Postby alvarz » Sun Jul 03, 2016 1:32 pm
Greetings to all and thank you for all the valuable information you have provided me thus far while I silently surfed the forum over the last four years. I own a 2007 210 Outrage with the leaning post livewell option that I'm contemplating removing for a barebones leaning post/seat. My purpose is to gain a more open area as I don't use the live well, and prefer to troll using artificial lures.
I would appreciate your input in regards to the problems that I will likely have to address: the deck openings, the through hull fittings leading to the live pump, etc. Thanks!
porthole
Re: 210 Outrage Leaning Post Livewell Modification
Postby porthole » Mon Jul 04, 2016 10:25 am
Where are you located?
Duane
2016 World Cat 230DC
1997 Outrage 18, Yamaha 125
1983 15 SS, Honda 50
1980 42 Post
1983 34 Luhrs 340 SF
Postby Phil T » Mon Jul 04, 2016 10:46 am
alvarz
Postby alvarz » Mon Jul 04, 2016 5:08 pm
Phil thanks for the diagrams. I see the piping comes thru a single access port, which I imagine I can fit with a tank cover. Then the screw holes would need patching - Can anyone say if that would require fiberglass or simply caulk?
I'm in Fort Lauderdale.
Ed
