2001 SUPER SPORT [13 Molded Fiberglass] Thwart [Seat] Repair
Posted: Mon Oct 27, 2025 9:09 am
On my son's 2001 Super Sport [13] the [molded fiberglass] thwart [seat] is cracked right across the middle, just to the port of the helm console. This happened because a previous owner attached something heavy to the underside of the [molded fiberglass] thwart [seat] with screws and did not seal the screw holes, so water got into the foam [interior of the molded fiberglass thwart seat].
The gelcoat and fiberglass on the top [surface] of the [molded fiberglass] thwart [seat] are apparently in good shape.
REPAIR METHOD
I purpose to grind out all the [fiber]glass [and] foam [on the] under[side of] the [molded fiberglass] thwart [seat], leaving the top [surface fiber]glass and gelcoat [layer] intact. Then I will [use] epoxy [resin to seal and adhere] either the closed-cell foam or [newly added] marine plywood, [bonding it] to the underside [of the molded fiberglass thwart seat], and then cover [the repair] with [some sort of woven fiber]glass [cloth].
Q1: am I on the right track [with the repair method described above]?
Also, any suggestions given will be welcomed.
REPAIR METHOD
