1987 Outrage 22 Bilge Pump Bracket Mounting Screws
Posted: Tue Jul 21, 2026 8:26 am
Q1: Is there anything that needs to be done to prevent water intrusion into the foam from the screws that are drilled into the bilge area to hold the bracket in place since there is always some water left that the pump can't get to?
Q2: If I need to drill out wider holes to fill with something to isolate the screws from the interior of the hull what sort of drill would I need to use to drill into the gelcoat/fiberglass?
Q3: are there any other common areas on an 1987 OUTRAGE 22 I should inspect and address for repair?
Background: I bought an OUTRAGE 22 notched transom at the end of the 2025 season that already has the bilge pump installed but I want to make sure to seal anything that could allow water to soak into the foam. The starboard side of the boat already seems a bit heavier than the port side at rest and I'm not sure if this has anything to do with it, but would want to take whatever precautions I can as my old outrage 18 seemed to be heavier on this side as well.
