2009 SUPER SPORT 13: Poor Performance and Static Trim Suggest Water in Hull
Posted: Sun Jul 26, 2026 12:46 pm
Give me advice on how to remove water from the foam of the Unibond hull of a 2009 SUPER SPORT 13 [which is assumed to be there due to poor performance and the static trim submerging the stern hull drain several inches below the waterline].
BACKSTORY
In Spring 2026 I bought a 2009 SUPER SPORT 13 with a Mercury 40-HP.This older is the first Boston Whaler boat I've owned in 25 years. Previously I have owned a c.1960 13-footer. Later I owned an OUTRAGE 18.
I have had the boat in the water a few weeks now, We're loving the Super Sport 13' and it's been fun with the family for cruising around and fishing inshore in Massachusetts. Having owned an old very and wet 13-footer, I was expecting some water in the hull of this 2009 boat.
There really seems to be a lot [of water in the hull in the foam of the Unibond hull] . The boat is sitting rather low in the water.
It will get onto plane, but even with just me (200-lbs adult man) aboard, the 40-HP engine needs to run at 4,500-RPM to maintain the boat on plane. When my wife and two small children are also aboard, the engine essentially has to run at full-throttle to maintain the boat on plane.
When at the dock in static trim with the 6-gallon on-deck fuel tank at FULL, the drain at the stern is completely submerged, and I have to leave that drain plugged continually.
We're going to enjoy the boat this season and I'd like to try to remove some of the water over the winter. I've seen a bunch of posts about people having both good and bad luck raising the bow and drilling a few small holes in the stern. I may be able to find a heated garage space to keep it and if people think this will make a big difference, I might try harder to find the space. Otherwise it will be in my yard.
ASIDE
I'm sorry if this is an annoying first post. I've been reading here and other places on the web for the past couple weeks and decided that the best thing is for me to start a new thread. I'm looking for some advice and it seems that there is a wealth of knowledge on this forum. Again, sorry if this is a question that gets asked all the time.
BACKSTORY
ASIDE
