Q1: what [aftermarket molded fiberglass] center console is available that could be used to convert a SUPER SPORT 15 to a center console model and not cause the appearance to be too off?
In 2025 I bought a 15-footer that has the center [rigging] tunnel in the hull [that normally would be found on a center console model, but this boat is fitted out as] a SUPER SPORT 15 [with the steering on the starboard side].
The steering wheel is too low. [To increase the height of the steering wheel] I may use a 20 degree spacer and tilt the wheel up. Or, I may move the steering wheel to the top of the console--like the SPORT--and tilt it back.
