Attaching Temporary "Transom Board" for 1987 Outrage 22
Posted: Sat Oct 03, 2026 7:43 am
Q1: What can I use to temporarily attach PVC board (baseboard from Home Depot) to the top of the transom of a 1987 Outrage 22 notched transom to prevent water from coming over the back that will be easily removable when I am ready to come up with a more permanent solution?
Q2: Would 3M Dual Lock SJ3560 (Clear, Type 250) work for what I need to do? Or is there something else I should use, like C Clamps? I'm not looking to drill into the hull for the temporary fix.
Context
This is a temporary solution to use for up to a year or so (at least for the remainder of this season), so I need something that will not damage the gelcoat and that will be easy to remove. The water coming over the transom is moreso caused when the stern of the boat comes down when rocking in waves at anchor or drifting as opposed to a wave coming over the top. Even smallish boat wake waves will do this depending on the angle. So for the most part, there is not a huge amount of pressure that would be put on the board. In my old 1989 Outrage 18 notched transom where I am, it was very rare a wave would actually crash over the top into the splash well.
Context
