Water Tight Deck Plate to Dry Out Foam
Posted: Fri Aug 12, 2016 12:33 pm
I am new to the Whaler Community as I have just purchased a 1983 13-footer. After having it now for a few weeks I am suspecting that it has wet foam. The hull is solid and has no [soft spots]. It is the topside that worries me. I do believe the floor has had a couple downrigger weights dropped on it.
I will be weighing the hull and doing a few other things to confirm my suspicions. If I do confirm it has wet foam my thought is to open up the floor with two six-inch holes, one fore and one aft, and install watertight deck plates. This would allow me to continue to use the boat as I wish and then unscrew the cover plate to help dry things out in the off days and over the winter when it will be stored upside down while I do some minor hull repairs. Once things have dried out sufficiently I would use the plug I cut out and fiberglass over the hole.
Any input on this approach would be appreciated.
