Repainting Entire Boat 13' 1972
Posted: Sat Aug 27, 2016 12:22 am
Looking for any insight from someone who has already taken on this project:
The paint is relatively expensive, and figuring I'll never paint anything else in Boston Whaler Blue (or at least not in the lifespan of a can of paint on the shelf) how much did you actually use on the inner hull? I see some places a quart will be enough, and others it takes upwards of a gallon?! Going to be using TotalBoat Wet Edge in BW blue. Not looking for a showroom floor finish, but want decent results. Will be doing 2 coats over primer. Using TotalBoat high build primer as well.
Same for the hull. Priming and painting white. I am already going to get a gallon of the high build primer, that should be enough. Will a gallon of white topcoat be enough for 2 coats?
Will also be using the TotalBoat TotalFair Epoxy Fairing Compound. These products have great reviews so far and are much cheaper than the (most likely better quality) well known competitors.
