Need M.E.K. or Klean Strip Advice
Posted: Sun Aug 28, 2016 7:36 pm
I'm going to remove several spots of old varnish from the interior of our 1981 Sport 13. A previous owner was a very sloppy wood finisher so I want to get things squared away.
The instructions on the MEK can say to mix four ounces to a gallon of water. I suspect that will be too dilute to remove old solidly adhered varnish from fiberglass. Unless I hear otherwise I will just use undiluted MEK.
The worst mess is the forward/anchor locker. Varnish is slopped all over the place and is a real mess. I need to know how best to remove the varnish. Most of the other varnish is smallish widely separated spots probably removable with MEK on a rag. The larger areas may do better if the MEK is painted over it, allowed to sit for a while, then wiped away with rags.
But, I really don't know how to use this stuff so how about some tips.
