15' Dauntless: 15 gallon Tempo fuel tank repair
thediscusthrower
Postby thediscusthrower » Tue May 16, 2017 1:13 pm
I am going to attempt a repair on my 15 gallon Tempo Fuel Tank (F-159?). Apparently, during the blow mold process, not enough plastic pellets were available in the upper corner, causing it to "spring a leak." I repaired it (or so I thought) only to have it start leaking again during its spring cleaning. During a recent visit to Tractor Supply Company, I found a tube of JB Weld's "WATERWELD" which appears to be specifically designed to fix this concern.
Anyone have any experience doing this? Any suggestions?
Bob
Re: 15' Dauntless: 15 gallon Tempo fuel tank repair
Postby Phil T » Sun May 21, 2017 2:52 pm
While it may work, your tank is pretty old. Moeller bought out Tempo Products back in 2008.
cf: http://www.tradeonlytoday.com/2008/08/moeller-marine-purchases-tempo/
Moeller dropped many of the Tempo tanks and made their version of some others. The closest Moeller tank is the 12 gallon high profile.
Walmart online: https://www.walmart.com/ip/Moeller-Low-Perm-Certified-Fuel-Tank-12-Gallon-with-1-4-Fuel-Pick-Up-Adapter-and-Mechanical-Direct-Sight-Gauge/37578366
Amazon https://www.amazon.com/Moeller-12-Gallon-High-Profile-Portable/dp/B004APHPYK
Scepter makes a version offered at Bass Pro Shops for ~100
http://www.basspro.com/Scepter-Rectangular-Portable-Fuel-Tank/product/2265117/
