Anchoring Steering Transom Pulleys
Posted: Mon Jul 31, 2017 9:42 am
I'm putting steering pulleys in an old Whaler and was looking at how they pulleys at the transom were anchored.
My pulleys have the typical "U" shaped stainless mounts with holes for 2 #10 screws in them.
Most photos I can find show these mounted on the transom or in the corner of the transom where it meets the side, but I'm not sure I think that just drilling a couple of holes and putting wood screws into the fiberglass is a safe way of mounting these.
How was it done by the factory on older boats?
My thought is that the best way is to mount them on the transom and drill a larger hole (like 3/8") in the inside, but not through the entire transom, just enough to clean out the foam to the back side. Then fill the hole with thickened epoxy and then put a bolt through the whole thing with good size washers on both sides.
