1983 Johnson 70 dies at full throttle
Posted: Fri Jun 22, 2018 9:35 pm
I was taking my kids tubing, and the boat ran great for 10 to 15 minutes. Then while pulling them the 1983 Johnson 70 engine died at full throttle. The engine would start back up and then die again after three to fine minutes. I got her back to the dock and would start it with choke and it would run fine then put it in neutral and it would die.
Within the last two months, I have changed fuel lines, installed a new fuel tank, and put in a new thermostat. And I only run REC-90 gasoline.
My first guess [at the cause of the engine stopping at full throttle] was [a lack of] fuel supply, but having changed lines I wouldn't think this is the cause.
Could [the cause] be the carburetors need cleaning?
Or I guess it could be something with the fuel pump or fuel supply. Maybe bad diaphragm?
Thanks for any input
