Revenge 25 transom bracket
Posted: Sat Jul 07, 2018 11:16 pm
I'm attempting to finish a project started by the previous owner of this 1982 Revenge 25. I've done all the research I can, but am still stuck with a couple things, and just need a sanity check that I have a good plan to complete this.
I plan to raise the transom around 7-inches for a total of 32-inches. This would put the top of the bracket just below the top of the transom. This would make for a nice step in and out of the boat. Following the top line of the new transom, I was thinking of extending the raised part on each side, so that the bracket would sit flush all the way across. The bracket would bolt through the transom and an aluminum plate.
Before the bracket goes on, I was going to glass in all the wood where the motor well was removed. Unfortunately I don't have the motor well to reglass in. So I was thinking of just doing a new floor there. But, I would like to keep access to the inside of the transom, so I'm not sure what to do there.
I was also wondering if I could take out the back of the splash well, so I have a level deck from cockpit to transom. Possibly with a 2" scupper on each side through the top of the bracket. And then I have a 1993 OMC 225 OceanPro ready to go on the bracket.
What do you think?
What do you think?
