Jack Plate or Redrill Transom for New Engine
Posted: Wed Aug 15, 2018 7:20 pm
by eli1exw
I plan to re-power a 1971 NAUSET 16 with a newer engine. The bottom holes on the transom bracket of the new engine don't line up [with the existing holes in the transom from the old engine mounting position].
I hesitate to drill blindly into the transom. I believe the holes would puncture below the splash well inside the transom, and there would be no way to get a bolt on from the inside.
Is a jack plate a better idea?
Thanks- Eric
Re: Jack Plate or Redrill Transom for New Engine
Posted: Thu Aug 16, 2018 8:45 am
Posted: Thu Aug 16, 2018 8:51 am
Older boats like a 16-footer will be sensitive to transom weight. Consider the new engine will itself weigh more than the original engine, and adding more weight with a jack plate could create additional problems from too much transom weight.
