SPORT 15: Location to Stow White All-Round Lamp
Posted: Mon Feb 08, 2016 5:53 pm
by BlueSmoke
I want to [stow the white all-round navigation lamp and its pole] somewhere on my Boston Whaler SPORT 15. There is no room under seat due to fuel tank. Are there any good spots I may not be thinking of?
I was going to use a Beckson clip. Or buy these nice ones with wood blocks.
Re: SPORT 15: Location to Stow White All-Round Lamp
Posted: Thu Feb 11, 2016 11:14 am
Stow the lamp and pole to the cockpit port side inwale, just below the level of the seats, near the transom.
To hold the pole of the white all-round lamp fixture, use these inexpensive rubber mounts.
Posted: Thu Feb 11, 2016 12:41 pm
by porthole
When I had my 15 I used two stainless spring clip brackets across the seat back. You can see them in this picture.
Posted: Thu Feb 11, 2016 1:08 pm
by Oldslowandugly
I used those same rubber clamps Jim mentioned, they work perfect. My intent was to mount the pole between the rail uprights, but I had extended the pole to about four feet which caused storage problems. I finally mounted the pole with four of the rubber clamps under the hinged wood bench I built to hide the gas tanks. This pic is in the early outfitting stages but I put the clamps along the inside rear edge of the box, to the rear of the gas tanks, easily removed even at night. Image
Posted: Sat Feb 13, 2016 4:54 pm
by BlueSmoke
Thanks for the ideas and the link to those clips!
I think I will wait to drill any holes as I may add a backrest which could be a great spot for it.
