Uflex Hydraulic Steering Cylinder Seal Replacement Update
Postby Jefecinco » Fri Sep 27, 2019 10:09 am
The use of a special pin wrench is no longer required for replacing the end caps. Uflex has redesigned the replacements. The new design has square faces permitting removal/installation with a common open end or adjustable (Crescent) wrench. This redesign vastly simplifies replacement of the end caps. The cost remains approximately $25 per end cap.
