1978 Montauk 17 or 1960 Nauset 16: Re-power with 130-HP
Posted: Fri Oct 04, 2019 8:18 pm
BACKSTORY:
I have a 1969 Nauset 16 with a 2018 Yamaha 90. Unfortunately , the NAUSET 16 was damaged during Hurricane Humberto--I am Bermuda based--when another boat broke free and took a large section out of the bow. There is quite a lot of damage to the NAUSET 16 along one of the chines where glass was worn out and separated from the foam, where the boat rode on a dock for a while during the storm while I bailed her out and then moved to a better location. (I will look for advice on repairs via a different thread as I do want to save her.} The Yamaha 90 engine escaped unscathed.
Since the storm, I have gotten my hands on a 1978 Montauk 17 hull in pristine shape. Part of the purchase deal was taking a Yamaha V4 130-HP two-stroke-power-cycle engine. I don't know the engine age, but this 130-HP is probably at least 8 to 10-years-old. It is not from the boat purchased, but as noted, was part of the purchase agreement. I reckon the 130-HP weighs 358-lbs, and let us assume it is in good shape for the sake of this discussion. (And it is in good shape in truth.)
I am in the camp of the Yamaha 90 being the perfect engine for Whaler 16/17 hull. I am inclined to move my Yamaha 90 to the new MONTAUK 17 boat which will become my main boat and then put the 130-HP on the repaired 1969 NAUSET 16 when it is back in the water.
Usage of my Boston Whaler boat s what I would call light-to-medium" : rarely pounding along in four-foot waves; more usually just inshore journeys in 0 to 15-knot winds and not much sea; rarely loaded with maximum number of people then driven hard; never taken way offshore here.
QUESTIONS
Q1: Is the 130-HP just out of the question too heavy for either the MONTAUK 17 or the NAUSET 16?
Q2: Is the 130-HP just not optimal, but would be fine if mounted on the MONTAUK 17 or NAUSET 16?
I keep fuel, battery and everything else out of stern and forward anyhow to balance the vessel. I am aware that the factory indicates 330-lbs Max but that they have seen up to 410-lbs but note it requires redistributing some weight to the bow.
Wwhen the Yamaha dealer mounted the 2018 90-HP on the 1960 NAUSET 16 in 2018, they had to mount the lower bolts into the engine well; they cut a 5-inch hole, dug out the foam back to the bolts, fastened them, then put an inspection cover over the opening. The dealer said the mounting holes had changed on the 2018 Yamaha 90 from the 2000 Yamaha 90 I had on previously
Q3: is [the mounting procedure used on to mount the 2018 Yamaha engine on the 1960 NAUSET 16 required] for a 1988 Montauk as well?
The mounting holes on the 1988 MONTAUK 17 boat are from a very old Evinrude 75-HP.
Q4: will the mounting holes from "a very old Evinrude 75-HP" match [the mounting holes on the bracket of a 2018] Yamaha 90?
I think someone out there will have knowledge about mounting holes.
When I get my hands on the 1988 hull I can check, but I am not getting it for a few more days.
Thanks in advance for any input on the engine weights and the mounting holes.
Soho
QUESTIONS
Soho
