Stainless Steel Tubing for Through Hull Drain
Posted: Mon May 11, 2020 2:46 pm
by CapeDave
[Have the] military specification quality stainless steel tubes sold by McMaster ever [been installed as through hull drains on a Boston Whaler boat]?
Stainless steel tubes are [more costly than brass tubes, but by using stainless steel tubing there is an expectation that] the drain would not need to be replaced [again].
Re: Stainless Steel Tubing for Through Hull Drain
Posted: Mon May 11, 2020 2:54 pm
Stainless steel is not a preferred material for drain tubes on a Boston Whaler. It is more brittle than brass and I doubt one could flare the tube without it splitting. Brass was chosen for this reason [i.e., it is ductile].
Posted: Tue May 12, 2020 12:18 am
by RichS
In a
prior discussion I remarked I was able to form 1.25-inch OD x 0.035-inch 304 stainless steel tubing into a replacement drain tube for the transom of my 1988 Outrage 18. I used a homemade flaring tool which looks very similar to those available commercially.
I ordered some 1-inch OD x 0.035-inch 316 stainless tubing from McMaster-Carr for the two smaller drain tubes. As of now, I haven't made the flaring tool for the 1-inch OD 316 stainless steel, so I cannot say if [tubing of that diameter and that alloy] will form easily.
I hope to finish the job before the summer. When the job is finished, I will post the results. There is more information and five illustrations in the thread:
Stainless Steel Through Hull Drainshttp://continuouswave.com/forum/viewtopic.php?f=6&t=3101
Posted: Tue May 12, 2020 7:06 am
by CapeDave
Rich--[the prior discussion on Stainless Steel Through Hull Drains] is just [the information] I wanted. Thanks.
