Rust From Embedded Metal in Deck
Posted: Wed May 05, 2021 4:56 pm
Q1: Did Boston Whaler use a metal fastening component below the deck laminate of the 17-foot hulls made c.1987?
BACK STORY--LONG STORY--GET SOMETHING TO DRINK
Hello CW. I'm a new to this forum but participated in the old forum.
I modified my [1987--always use four digits for years] SuperSport 17 hull to a [Center Console] between 2012 and 2014. At that time, I cleared the deck of all attachments from the previous owner and from Boston Whaler. With nearly every deck screw or other fastener and hardware removed I used West System epoxy to fair and seal the deck penetrations.
Due to more than 60 fastener hole repairs, the non-skid pattern looked pock-marked with 3/4-inch-diameter to 1-inch-diameter repairs, so I prepared the entire deck for AwlGrip finish with Griptex. I am satisfied with appearance, the performance, and the durability [of the refinished deck].
There is still a single fastener that I was not able to remove back then. As I recall, I likely just ground it to below the deck laminate and then filled and faired and on to the end objective.
That repair looked great, except over the last two years a rust stream has appeared over that filled divot. This boat is kept in the water year-round in southern California, and it is exposed to wet decks of humidity, wash downs, and rain. The decks drain and dry well enough, but the Griptex component for non-skid tends to hold moisture on the deck longer than the gelcoat non-skid did. But, otherwise, the entire deck drains dry after wash downs, rain, or morning dews, in a few hours. The bilge pump is always functional and vacates the sump down to the last one-inch of water.
Last week I decided to remedy the deck rust-bleed by removing the remains of the offending fastener by grinding around the perimeter to expose what I thought would be the remaining shank of a screw. I planned to use a VicGgrip plier to remove it. Then I was going to fill and fair; then be done.
After additional work with Dremel too past the laminate and into the 1/2-inch plywood, a bigger part of a fastener was reveled. I think the fastener is a large #12 or #14 screw, driven in at a angle, not vertical.
Since I did not want to make site opening bigger, I want to know about use of metal fastners or braces into the ply to connect to a bulkhead, beam brace, or other wooden deck support.
I've never heard of this before for in a Boston Whaler hull. I have never had reason to research it further than the "Wood Layout Diagram' for this model.
I've read here the 1/2-inch plywood decks were a "100% hull liner intergrated" construction product; supported only by the hull perimeter and the floatation foam, that is, contained no wood braces, supports, or bulkheads.
If [the source of this rust] is some type of original component, I'll live with that. Leaving it in and repairing over it is not a problem. But I'm sure in five years or less I'll see the rust bleed thru again.
This boat is not an show contender, but I do focus on keeping the hull sealed and dry to keep fishing and cruising it offshore at least nine months of the year.
At this point, presuming this metal remnant is not an original part fastener and should be eliminated entirely, I plan to use a hole saw and drill around the fastener. Once out, I'll plug the hole. Right now the object looks like remnant of a large screw by previous owner. The remnant still buried through the plywood and looks clean and unruste], which tells me the laminate-to plywod bond' is still a water seal. Noneth less, I've gone this far. I am resolved to remove it.
I just want to be certain metal remnant isn't a necessary originally installed deck component--and seriously doubt it is.
The general location is 15-inches forward of front of sump, 16-inches from l[Port] deck gutter[possibly where front face of rear mahogany bench seat may have located on this former Super Sport
Appreciate any relevant thoughts or advice. Thanks--Joe
