2014 Mercury 90 FOURSTOKE No Start
Posted: Sat Oct 16, 2021 6:35 pm
[My 2014 Mercury 90-HP FOURSTROKE engine] stopped suddenly with [a diagnostic] message [that said] something like "Voltage Problem."
[Now when the ignition switch is move to RUN from OFF with the battery switch set to] A, or to B, or to BOTH, nothing turns on.
I am certain that both battery A and B are good.
Before the breakdown, the batteries were NOT charging in neutral but were charging in gear with typical increase in voltage upon more power and this as observed on a Voltmeter.
[Give] advice [on the cause].
